TUI command for patching region
Old   August 13, 2007, 14:28
Default TUI command for patching region
Tristan Collins
I am trying to patch a region of my domain. I use the following command to select the region:
/adapt/mark-inout-rectangle yes no 0 0.001 0 0.008
I then want to patch a hot temperature using "/solve/patch".
How do you enter the command to not select the entire domain, but just the region that has just been made? To put it another way, how do you 'enter nothing' as an option?
/solve/patch <what goes here??> temperature no 1800
Thanks,
Tristan
Old   August 13, 2007, 15:58
Default Re: TUI command for patching region
jasond
I believe the answer to your question is "," (a comma) - it is just like hitting the Enter key interactively. So, this should probably work:
/solve/patch , , , temperature 1800
Jason D.
Old   August 14, 2007, 04:53
Tristan Collins
Thank you!
Trawled the manual for ages looking for this info...
Tristan
Old   May 6, 2019, 06:19
Default Unsteady TUI sample
milad
milad alizadeh is on a distinguished road
Hello
I am trying to write a journal TUI file for unsteady sample.
Can everyone help me to write a command for unsteady case and also patching two regions?
Best regards
milad alizadeh is offline   Reply With Quote
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
