Specifiying rotational axis' - a bit stuck
Old   August 28, 2007, 05:40
Default Specifiying rotational axis' - a bit stuck
Dave
Hi everyone
I have 3 turbines in a volume and wish to rotate them all. I have actually posted about this before but i have come across a couple of issues.
- when i specify my rotational axis origin for each of my walls, which point should i choose? Is it any point along the line which runs normal to the wall plane? (through the middle of it)
- when i am specifying my rotation axis origin for my fluid (water) do which point do i choose fort this? I have tried the point in the centre of the inlet face but this gives wrong results
Im pretty stuck here, so any help would be most appreciated
Cheers
D
Old   August 31, 2007, 05:18
Default Re: Specifiying rotational axis' - a bit stuck
chandra manik
rotation axis is vector quantity, when fluid zone rotated in center of coordinate, you need spesified what is axis, typicalluy in x, y and z, see your geometry to find its x,y, z direction ( if x your axis, you shoul type x=1,y=o and z=0, instead of case y as rotational axis, x=0,y=1 and z=o)
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
[ICEM] Rotational periodicy setup Procyon ANSYS Meshing & Geometry 0 April 30, 2011 07:55
64 Bit software or 64 bit compatibility? EphemeralMemory ANSYS 1 August 31, 2010 05:29
Writing Moment coefficient for different walls at different rotational axis harishameed33 Main CFD Forum 0 April 27, 2010 12:17
Defining a moving rotational axis! Samuel CFX 3 September 12, 2007 10:00
