Pressure boundary conditions
Like Tree6Likes
Old   August 6, 2014, 03:02
amin.z's Avatar
Amin
amin.z is on a distinguished road
Originally Posted by chaudhry_hashim View Post
Hi I am quite new to CFD i am trying to find out the fan curve. My fan diameter is 71mm and what did uptill now I made inlet duct 15 times of fan dia with pressure inlet (0.0 Pa), outlet duct 30 times of fan dia with pressure outlet (0.0 Pa) and I am giving fixed rpm to the rotating region in between. I am measuring pressure in inlet and outlet duct at a position 10 times of fan dia. but Still I didnt find the relevant pressure difference across the fan and also the solution is not converges. If i want to give the value of dynamic pressure at the inlet then how can i calculate this value as i know the flowrate.
Although I am working in the same way as hiras worked that I am using steady state solution, MRF, pressure-inlet/pressure outlet conditions, k-e standard.
I have attached the pictures of model and mesh kindly take a look and also let me know whether my geometry is correct or not
I would be very grateful if you people help me out
Hey!
If your angular velcity is great it can make difficult to convergence for solver!
In this conditon, starting with a low velocity could help you for convergence!
amin.z is offline   Reply With Quote
Old   July 22, 2015, 02:59
Temidayo
techtradezone is on a distinguished road
Hi guys, I first of all appreciate everyone here, I am new in here and new to CFD. i am working on inpipe turbine. I used 1.4 m/s inlet and unknown outlet in autodesk cfd, with 3Xdia upstream and down stream. I initially ramp up the rotatin region to 2400rpm as an ideal RPM, then later change the rotating region to free spinning then further time step till another steady state RPM was gottn. but i dicover that my unknown volume flow rate is higher than inlet after the simulation. also, when i plot the inlet point and outlet point i discover that my result inlet velocity is higher than the what i initially specified. pls guys i need ur help
techtradezone is offline   Reply With Quote
Old   July 27, 2015, 01:38
hashim
hashim is on a distinguished road
hi, which approach are you using means MRF or any other
second, what does unknown outlet means, are you using pressure outlet and also is your mesh is fine enough?
kindly clear these things i will try to help you out
hashim is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Pressure Boundary Conditions Dave FLUENT 2 June 8, 2009 17:05
pressure boundary conditions A.Shaija Main CFD Forum 0 June 30, 2006 00:51
How to Define Pressure Boundary Conditions? Sheenu Main CFD Forum 4 May 12, 2000 12:52
