Absolute Pressure and temperature limited to......
Old   August 31, 2007, 14:29
Default Absolute Pressure and temperature limited to......
Shamoon
I am using unstructured mesh of 2.1 Million grid with sea level conditions.
After running 50 iterations Fluent displays the messages like
Abslute Pressure limited to 1.00e00 Temperature limited to 100K Time step reduced in 300 cells
And continued till end (alhough not converged)
What should I do?
Old   August 31, 2007, 15:09
Default Re: Absolute Pressure and temperature limited to..
Glenn
This typically means the solution is going numerically unstable somwhere (may be only for a few of mesh elements)and the solver is struggeling. If the solution is just starting, it may be that the flow field tried to permutate too drastically. You can try to recover by: 1) reducing under-relaxation factors to low values to start a solution... or 2) setting variable limits to more reasonable ranges... 3) "Patching" the pressure and/or temperature region to a more reasonable value.... or 4) examining your mesh for ill-posed mesh (run mesh quality checks in your meshing package)...repair poor mesh as appropriate.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
temperature limited - absolute pressure limited Asashi FLUENT 3 July 18, 2014 09:51
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
why absolute pressure and temperature limited to 1.000000e+00? wildli FLUENT 1 January 28, 2010 01:25
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
