how to calculate mass flow at pressure boundary |
Hi Users!
How does Fluent calculate mass flow at pressure boundaries? The user's guide says m'=sum(density * dot(velocity, area)) but when I try that I get a completely different answer. I've exported node coorinates to calculate area, and cell values of axial and radial velocity, and calulated in excel. There is a problem the Fluent reports non-zero velocity at the nodes on the walls - could this be related? Thanks for any clues? Hugo. |
if you using 2D analysis, first make reference value
Hi Jones,
Please could yu repost that, as it got cut off. thanks, hugo. |
Boundary condition for exhaut flow with imposed mass flow | stephane | FLUENT | 1 | November 24, 2011 02:04 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Mass flow BCs and Pressure differential BC | CFDLife | CFX | 5 | January 26, 2009 07:14 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 14:03 |
