Flotation Cell Help
Old   October 29, 2007, 16:25
Default Flotation Cell Help
Neetin Lad
Good evening.
I am trying to create a rotor stator system wit flotation cell. i am using something similar to a outokumpu impeller. a rotating set of blades inside a diffuser. in Gambit, i have done to scenario's , i have made 2 volumes, with one common cylindrical face, (one rotating inside the other), and 2 volumes with 2 common cylindrical faces ( one overlaps the other). the interface of these cylinders sits inbetween blades and diffuser within the fluid zone not on the solid.
Howver i cant seem to get this to work in Fluent, i have read all the manuals. does any body have any insight on this topic?
Old   October 29, 2007, 19:15
Default Re: Flotation Cell Help
Javier Larrondo
What type of error does Fluent show you? What type of MRF are you using, sliding mesh, mixing plane? Cheers, Javier
Old   October 30, 2007, 05:03
Neetin Lad
I am using sliding mesh, if i use the way of two volumes with 2 interface faces over lapping i get a nopositive volume exists message, and if i use the two volumes split in two - i just get either Fatal error - or simply Divergance detected before any iterations occur.
Help Me, what's the Cell Above any given cell in 3D. gomane8 Main CFD Forum 3 September 11, 2011 21:29
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
How to determine the direction of cell face vectors on processor patches sebastian_vogl OpenFOAM Running, Solving & CFD 0 October 27, 2009 08:47
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Warning 097- AB Siemens 6 November 15, 2004 04:41
