Pressure more accurate than velocity field?
Old   October 29, 2007, 21:03
Default Pressure more accurate than velocity field?
jrg
Is it correct to assume that the pressure field in most CFD simulation on laminar incompressible flow is likely to be more accurate (ie. closer to the truth) than vector field?
Or put in another way, is it easier to get good pressure data compared to velocity? Easier in the sense that a not-so-good mesh and/or a first order momentum upwind can still produce reasonable pressure data.
Thanks
Old   October 30, 2007, 11:11
Default Re: Pressure more accurate than velocity field?
Chandra Manik
I prefer to velocity, though knowing the pressure field can be use to find velocity field and also opposite condition.
Channel flow: Inlet pressure AND uniform velocity? frmap1 Main CFD Forum 0 April 15, 2010 10:32
Pressure Inlet Velocity prapanj OpenFOAM 11 June 23, 2009 11:15
custom pressure field at the faces Souviktor FLUENT 0 April 3, 2009 08:09
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
