Water level at outlet(VOF)
Old   November 8, 2007, 00:57
Default Water level at outlet(VOF)
Umm
hi, i'm doing a free surface simulation in which i need to keep water at a desired height at the outlet What bc shall i use and what parameters shall i specify??
Old   November 8, 2007, 04:35
Default Re: Water level at outlet(VOF)
andy
Hi, if you need to keep the water at a desired heigth at the outlet, you can use the VOF model with the option "open channel". At the outlet, a "pressure outlet" with the open channel option will work. hope that helps
Old   November 12, 2007, 00:40
Umm
ThANKS the reply.. i'm using fluent 6.1.22 Where do i select this option of open channel??
Old   November 12, 2007, 06:06
sushii
Go to Define>Model>Multiphase>VOF there you will get this option... for Open channel flow..!
Old   November 12, 2007, 13:46
winter
there is no such function for 6.1. only 6.3 has
Old   November 12, 2007, 23:48
Umm
So whats the remedy in fluent 6.1.2
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
height of water level in two-phase flows? Michael Bo CFX 2 August 23, 2004 01:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
