November 9, 2007, 14:29 |
Flow around a car
Dear FLUENT user;
I want to simulate the flow field around a car. I know that I shoud set the ground as a moving wall, but I do not know that how can I model interaction of the wheels and the ground. Should I make a very very small distance from the wheel and the moving ground? Many thanks, ROOZBEH |
November 27, 2007, 03:28 |
Re: Flow around a car
hi
since only the flow around a car does it require to model Ground as a moving wall? Hari V.B. |
November 27, 2007, 04:23 |
Yes, certainly the ground should be modeled as a moving wall with the same velocity as the free stream velocity. The flow fild will be fundamentally different if the ground is set as a stationary wall.
best regards, ROOZBEH |
3D Supersonic flow over a car | TeQuiero_Q8 | FLUENT | 0 | August 13, 2009 03:42 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Flow field analysis around the car | Cenk | FLUENT | 1 | December 26, 2003 18:09 |
