Hi ! I am working in a 2D open channel with VOF,two phase:air /water.The flow depth at the inlet is specialed ,and I get the free surface ,but how to compute the flow depth at outlet? Just multiply Area by volume fraction of water?
Thanks! rodi |
Hi, you donīt need to set the depth of water at a outlet. You should only patch the domain according to the physics and adjust the correct backflow at the outlet.
Enjoy your calculation bye, Jan |
Thank you! Maybe i can express my question much clearly~
When the caculation has done,and i got the free surface.During the postprocessing,I want to know the water level at the outlet,what can i do? For 2D simulation,the channel is rectangle. Can i just multiple the water phase fraction by the area of outlet? Thanks! rodi |
dear rodi you can find the height of water at the outlet from the value of vof at outlet directly by trial and error from the following relation: RL=(1/pi)*(pi-acos(2*(hL/d)-1)+(2*(hL/d)*SQRT(1-(2*(hL/d)^2))
where RL is the vof of liquid (water) & hL is liquid height I hope this fullfill your request another thing I sent you two emails envolve some questions about your case file which you sent me did you see it or no? did you see my case & data file too? hope to see your reply soon cheers kb |
What is Backflow....and how dose it affects the calculations...? Sometimes when simulating I set backflow volume fraction and backflow turbulent KE....to zero...does it affect the solution...? if yes then how to calculate right backflow volume fraction and turbulent KE...?
---Sushii.. |
#6 | |
Rep Power: 16 ![]() |
I am Rahul. I am also working on Open Channel Flow in Fluent solver. I used Mass Flow Inlet bc mass flow of air is 7985.6 kg/s, free surface of water is at 2m, bottom at 0m, Pressure Outlet bc In my case the, the channel is rectangular of cross section 4mx3m. Out of 3m height upto 2m there is water. Now I really dont understand what boundary condition should I use for remaining 1m. The geometry is attached herewith. One more thing to be discussed is that, should I patched volume fraction of water( secondary phase) initially through out the domain. I am trying for steady state simulation. If somebody have a test case for open channel flow pls do send me on praghanmor@gmail.com Hoping for ur fruitful suggestions. Thanks. |
Hi rahulrp
what does your mesh look like? darp |
anonymous
Rep Power: 15 ![]() |
I you take mass flow inlet boundary for open channel, then both water and air can enter from the same. Specify free surface level Specify bottom level Specify mass flow rate of water as = rho_water *Area_water*Velocity Specify mass flow rate of air as = rho_air* Area_Air * Velocity You can use the same velocity for both water and air. |
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 16:26 |
how to use Up Stream boundary condition in open channel Flow | ms.jafarinik | FLUENT | 0 | April 18, 2010 14:38 |
Open Channel flow Boundary | khalid | FLUENT | 1 | November 4, 2006 11:53 |
SIMPLE Scheme for open channel flow | ao | Main CFD Forum | 0 | April 6, 2004 16:21 |
