November 27, 2007, 04:06 |
udf for ehd
I written udf for transport equation for solving charge density. in my udf
1 i solved for voltage using uds0 2 using above uds i solved for electric field define_adjust(domain,t) 3)using 2 I solved transport equation for charge density by using macro define_uds_flux(name,f,t,i) IF u see this paper they described problem.u can see domain. ***for boundary conditions------------------- AT wire voltage =25kv at collector plate voltage = 0 remaining is symmetry BUT charge density on the wire is not constant. THIS will varry based on electric field. THIS is solved by iteratively . for this i written udf using define_profile() i supplied this profile to on the wire. but i did not got the results. PROFILE IS charge density on wire_new =old_charge+q*(1-alph) alpha is under relaxation q*=Ewire/Eonset Can any body give any advice on this . |
November 28, 2007, 00:50 |
Re: udf for ehd
hellow is there any one is there to discuss on ehd
May 26, 2009, 15:16 |
Akour
Ive seen this 2 years late but I would like to model EHD in fluent as well...I was wondering if you could give me any advice on how to write the UDF for the charge transport equation, I ask because there is also an ionic drift term...but the general scalar transport equation only has a diffusion, unsteady and convective flux term (and source term if you put one in). Any advice or references that you could point me too I would really appreciate. Im sorry I cant be of any help Thanks again akour |
May 10, 2011, 04:41 |
john
If any body has writted UDF for Guass law electric field or particle charge equation. Please share. john |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
