GAMBIT, CAD import, clean up geometry problem
Old   December 10, 2007, 04:21
Default GAMBIT, CAD import, clean up geometry problem
Nuray Kayakol
When I import ACIS file (*.sat) in the geometry some lines appears as green lines having no vertices. I couldn't connect those lines to blue lines. What should I do?
Best Regards Nuray
Old   December 30, 2007, 11:43
Default Re: GAMBIT, CAD import, clean up geometry problem
marco brunaldi
i think that the green part isn't solid body . 1)please try close surface and connect surface connect surface with the 3th option and t-junction or virtual connex
Import geometry from CAD Giuseppe (Giuseppe) OpenFOAM Pre-Processing 34 December 14, 2017 16:24
problem importing mesh into gambit tsm554 FLUENT 7 December 3, 2010 22:15
[GAMBIT] Geometry problem with gambit (intersection pipe) Zweeper ANSYS Meshing & Geometry 0 October 20, 2010 14:41
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 10:26
