December 11, 2007, 09:55 |
Time for fluid replacement
I'm working on a VoF-model of a quickfilter for water treatment. Water is pumped upwards through a zylinder and flowing out over the edge of a funnel inside of that zylinder. The system is open to atmosphere. What I'm interested in is the time it takes to replace the water in the system. Could it work to use VoF and define a third phase (water-new) additionoal to air and water-old, as VoF is ment for non-interpenetrating phases? Any suggestions? Thanks, Andreas |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
Time step in transient simulation | shib | FLUENT | 0 | June 17, 2010 13:07 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
