Convergence problems in multiphase flow!
Like Tree3Likes
  • 1 Post By rana
  • 1 Post By Emmery
  • 1 Post By Mikael
Old   December 11, 2007, 10:01
Default Convergence problems in multiphase flow!
Mikael
I´m doing simulations for a helically coiled tube containing a liquid phase along with granules in the Euler- Euler multiphase solver. The problem is that I can't get it to converge. I started out by solving the flow without the volume fraction and got the residuals down to 10e-4 and then they flatened out. After that I added the volume fraction and got the residuals to decrease some without occilations. But after a while residuals starts to occillate very much. I have tried to lower the under relaxation but it didn't help. Somebody who knows what could be the problem?
Another thing is: is it necessary to use mass flow inlet, can't one use velocity inlet instead (the fluent manual says one should use mass-flow-inlet)?
//Mikael
Old   December 11, 2007, 13:27
Default Re: Convergence problems in multiphase flow!
bashu
Are you running transient? If not you probably should.
Old   December 11, 2007, 17:18
Mikael
I have tried solving transient and steady without any results. Same behaviour in both cases. I can add that I'm solving laminar because I got a Re-number of around 70.
Old   December 12, 2007, 06:00
rana
it is difficult to converge this kind of problems in both steady and unsteady state i feel if your residuals do not diverge, then you can accept them as acceptable results.
before that, check for your under-relaxation parameters (do not decrease them too much even) and method of discretization
keep us posted..this is a genuine problem in multiphase flow
jipaz likes this.
Old   December 12, 2007, 10:39
Emmery
you can check the main variables at some strategic points in the geometry. If their values are not evolving with iterations or has a periodic evolution (transient), then it can be considered as converge. Cheers
jipaz likes this.
Old   December 13, 2007, 11:01
John Yang
Multiphase flow problems in FLUENT is not well solved,so how about modify your mesh file or boundary conditions and try it again? Some problems are grid-sensitive.
Old   December 13, 2007, 15:11
Mikael
Thank you for the help, I have now tried to change boundary conditions between velocity inlet and mass flow inlet without any result. Changed discretization also without results. However I havn't tried to change the grid so maybe I can try that out (my grid has very low skewness thou). So far I have gotten the massbalance to match between inlet and outlet to 89% accuracy, not that god...
jipaz likes this.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Multiphase Flow - Convergence Problems bastian26 FLUENT 0 September 19, 2011 07:26
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Multiphase flow convergence problems Nick CFX 1 July 12, 2007 21:18
