Accessing node values using a UDF
Old   December 17, 2007, 11:48
Default Accessing node values using a UDF
Nico
Hi!
I am trying to write a UDF in order to create a file with the node loads. I know that in post processing it is possible to obtain a file with, for example, the pressure at the nodes of a solid boundary, and that FLUENT calculates node values as the average of neighboring cell data. My problem is that i need to obtain node values using a UDF. My question is, what's the best way for accessing node values? In particular, i need to access nodes belonging to a solid boundary.
Thank you very much in advance!!
Nico
Old   December 17, 2007, 11:59
Default Re: Accessing node values using a UDF *NM*
Nico
Old   December 20, 2007, 02:50
Raj
Nico,
There is a macro in fluent C_node_loop(..) which loops over the nodes in the selcted thread.Within this loop u can insert a message or printf statement to print it for you. You can use this macro in DEFINE_ON_DEMAND function.
Hope this helps
UDF Global Node Number ? C. H. FLUENT 1 November 24, 2006 10:02
How to obtain node values in UDF? Maciej FLUENT 0 October 23, 2006 08:10
node based or cell centered Ts values acboge FLUENT 0 February 6, 2004 06:41
printing values from udf!!! Shekhar FLUENT 2 January 13, 2004 11:49
Help: how to get node values with UDF? Dazhi Guo FLUENT 0 February 4, 2001 00:59
