Convergence Problems Internal Flow
Old   January 24, 2008, 09:54
Default Convergence Problems Internal Flow
Haroon Junaidi
Hi Guys,
I am using a relizable K-Epsilon model for evaluating the pressure drop through a duct.
The solutions seems to be converging but I have setup a monitor for pressure at the inlet and it keeps fluctuating as much as 30%.
Taking the middle value for pressure in case of fluctuation would be a logical argument, however the fluctuations are random and donot have a pattern.
Would really appreciate if someone can give any pointers.
Best regards
Haroon
Old   January 25, 2008, 06:06
Default Re: Convergence Problems Internal Flow
kk
i am also have duct flow we may can cooperate with this send your mail.
Old   January 30, 2008, 07:40
Carlos
Are you sure your solution is converged? Are the residual gradients flat and level and have they been for long enough? To be sure, lower the convergence level to say 10^-9 and let the simulation iterate for 5000 iterations. The pressure oscillations may dissapear.
Also, you are using a high Reynolds number turbulence model. Try the standard k-omega model or the k-epsilon RNG. These may give you better results.
Carlos.
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
problems for the flow over flat wall iilw1314 Main CFD Forum 0 March 19, 2010 04:53
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
High speed flow problems Sawa FLUENT 3 January 14, 2003 01:10
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
