February 4, 2008, 07:49 |
building geometry of an impeller in GAMBIT
Hi! GAMBIT users
can we build an marine impeller with this given data? 1.three flat blades attached to the hub. 2.blade pitch angle 45 degrees 3.diameter 0.036m If so,could you elaborate on the procedure? Thanks PKN |
February 4, 2008, 09:14 |
Re: building geometry of an impeller in GAMBIT
the model is built wiht the third software, like solidwork,e.g, then input into Gambit, where you will finish meshing, including setup hub,casing,period,etc; see the manual for further detail
February 4, 2008, 11:50 |
Thanks a lot jesse !
Is the data I mentioned earlier suffficient to build a geometry of impeller in the CAD? Thanks PKN |
February 4, 2008, 23:13 |
no. you need to have the profiles of blade, which has to be imported to ny CAD software or Gturbo
February 5, 2008, 03:16 |
Thanks a lot SAM!
may be, not the right thing to ask...how to get a blade profile of a three flat blade marine propeller with blade pitch angle of 45 degrees & having diameters of 0.036m. Any way....Thanks a lot! PKN |
February 5, 2008, 05:24 |
Do you have there goemtry with u or only physical part. ????
gambit open channel geometry | tplehn | FLUENT | 1 | July 21, 2009 12:04 |
Gambit geometry construction questions | yueke | FLUENT | 0 | June 25, 2009 14:50 |
3D geometry in gambit | Meenu | FLUENT | 7 | May 10, 2007 15:51 |
problem about Importing geometry in Gambit | Hua Gu | FLUENT | 3 | April 2, 2002 14:24 |
Creating a Geometry in GAMBIT | Sridhar | FLUENT | 2 | November 26, 2001 10:11 |
