inlet mass flow rate BC
Old   February 5, 2008, 13:24
Default inlet mass flow rate BC
manu
I'm simulating a 3d- compressor with constant mass flow rate - inlet boundary condition and constant static pressure - outlet boundary condition. When the solution have converged I find a positive static inlet pressure (on the inlet face). Normally it should be negative, as there is gas with atmospheric condition (== operating pressure) flowing through the inlet face. And the total inlet pressure should be zero (compensated with the positive dynamic pressure) Can somebody explain me where I make (or Fluent???!!!) a mistake?
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
Mass flow rate graph Lior FLUENT 0 March 7, 2004 10:02
Mass Flow Rate Calculation Paul FLUENT 9 March 23, 2002 08:37
