Residence time in VoF-model
Old   February 7, 2008, 09:32
Default Residence time in VoF-model
Andreas
Hello everybody,
I've got a vof-model of a zylinder filled with water and air. There is a velocity inlet at the bottom (water), a pressure inlet at the top(air) and a pressure outlet.
I want to study the displacement of "old" water by "new" water.
Species dosen't work with VoF and defining two water-phases (old and new) is no option as well, because VoF-phases may not be interpenetrating.
One workaround I thought of, was to create a new one-phase model with the previously optained water-air-interface-contour as a frictionless wall.
If anybody has some solution to my problem or could advice some link/literature/...
Thanks, Andreas
Old   February 8, 2008, 16:46
Default Re: Residence time in VoF-model
KW
You can use a user-defined scalar as described below. From Fluent tech support, also in Fluent UDF archive on User Service Center.
==================== Solution 619 Fluid residence time
Problem: Compute fluid residence time.
Problem solved via UDF using user-defined scalars. Source code for UDF is below.
1. Compile udf 2. Read case.... set # UDS > 0 3. At inlet, set UDS (value) = 0 4. Set diffusivity of UDS to a small value 5. Set source term of UDS to "rt_source" in the appropriat fluid zones 6. Iterate.
Values of UDS represent the length of time fluid has been in the domain since it entered the inlet (in seconds).
Resolution: ------------- #include "udf.h"
/* * UDF to compute fluid residence time * * by William Wangard, Ph.D. * Fluent, Inc. * */
/* * This UDF requires at least 1 UDS to be defined * At inlet, define UDS (value) = 0 * UDS will have units of time and represent approximate residence time * of fluid in domain * * Diffusivity of scalar should be small to reduce diffusion i.e. 1E-5 * */
DEFINE_SOURCE(rt_source,c,t,dS,eqn) { real source = C_R(c,t); dS[eqn] = 0.0; return source; }
Old   February 15, 2008, 06:47
Andreas
Thank you very much!
Andreas
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
urgent query regarding vof model plz rply Garima Chaudhary FLUENT 0 July 13, 2007 02:20
residence time Sugen Chetty Main CFD Forum 0 January 28, 2002 09:50
