meshing a fan using gambit
Old   February 13, 2008, 16:30
Default meshing a fan using gambit
tony
Hi, All,
I am new with gambit. I want to create a surface mesh for a fan and import it in CFX. The workbench can't mesh this thin surface so I am using gambit.
The fan is created in UG as 3D thin surface(no thickness). I imported it into gambit and created meshes on each faces of the fan. When I exported as mesh file, it did write out a .msh file but with a warning: At least one geometry entity has no mesh for export. Then in CFX the mesh file can't be imported.
What should I do to create this surface mesh in gambit and import in CFX?
Thank you so much for your suggestions!
Old   February 15, 2008, 00:28
Default Re: meshing a fan using gambit
Elleana
Hi Tony,
I really dont understand why you cant mesh that in CFX. It is simple surface meshing.
It looks like it is not writing any mesh file.
When you import that on to CFX what is the error you get.
When you are exporting a 2d mesh file in gambit it is a practice to create the geometry in the XY plane. Since it is 3d be sure to get the concepts right.
Thanks Kind Regards Elleana
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
