I am having some doubts over some convergence issues. The default convergence criteria for fluent is 0.0001. So if my solution converge with the default criteria it is correct? For a change, i set a very high convergence criteria 10^-10 my residual graph keeps going down until a point where everything starts to be in a straight line(constant), Do i use that results? it seems to be a more reliable result. |
when your results are converged, they stop changing.
ie. check then check again 100 iterations later, if they look the same then they are converged. |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
What value shall I set for the Convergence criteria? | steventay | CFX | 7 | May 14, 2010 12:44 |
convergence criteria | iuaniu | CFX | 3 | September 24, 2009 19:20 |
Convergence criteria | PrandtlGlawert | FLUENT | 1 | August 13, 2009 18:06 |
Convergence criteria | PrandtlGlawert | Main CFD Forum | 1 | August 13, 2009 17:13 |
