Axial, Radial, Tangental velocity in FLUENT post |
March 4, 2008, 04:51 |
I used SRF to model a compressor. I would like to show the axial, radial, tangential velocity on an iso-surface. Does anyone know how to show it in FLUENT post. Thanks a lot! |
March 5, 2008, 10:39 |
Re: Axial, Radial, Tangental velocity in FLUENT po
simpley go to contour menu
March 6, 2008, 20:29 |
1st create iso-surface in axial, radial and tangential at desired level. then go to contour menu. select velocity-velocity magnitude. then "from surface"-selct axial, radial or tangential option, as u create n want to plot.
Velocity Fluctuations in Fluent | Andrew | FLUENT | 14 | August 24, 2015 00:26 |
RMS velocity and reynolds stres with fluent | gina | FLUENT | 1 | May 20, 2013 04:05 |
difference of velocity field processed by CFD-POST and Fluent | Jiuan | CFX | 3 | June 16, 2010 08:23 |
Radial Position and Axial Velocity Graph | Sal | FLUENT | 2 | August 1, 2007 09:29 |
User defined rotational velocity in FLUENT | Abhinav | FLUENT | 1 | June 10, 2003 08:31 |
