Vorticity Direction
Like Tree6Likes
  • 6 Post By John Young
Old   March 4, 2008, 08:15
Default Vorticity Direction
Sham
Hi all,
I am simulating an oscillating cylinder and observing the vorticities. Does anyone know how to view the velocity in which the clock wise and anti clockwise vorticity direction gives you diff colour in the contour plot? This will make it easy to differentiate between positive and negative vorticity direction.
Sham
Old   March 4, 2008, 22:47
Default Re: Vorticity Direction
NRD
Your question is not entirely clear to me. However, if you want to look at the direction in which the vortices are rotating (i.e. whether clockwise or counter-clockwise) why not plot the velocity vectors?
Old   March 7, 2008, 00:58
John Young
Hi Sham, I'm assuming your problem is 2D, where fluent only provides the vorticity magnitude. To get around this you can define a Custom Field Function (see sect 30.5.1 of the user guide) for the vorticity which is du/dy - dv/dx. John
Old   March 22, 2008, 03:41
Sham
John,
Could you pls explain a little bit more how can I use the Custom Field Function to define the vorticity direction and show it in diff colour? I am modelling a 2D cylinder in free stream.
Sham.
Old   March 24, 2008, 16:15
John Young
Hi Sham,
Go to the "Define" menu, pick "Custom Field Function". Then in the "Field Functions" drop-down box, pick "Derivatives", select "dX-Velocity/dy" from the second drop-down box, click "Select", then the "-" button, then select "dY-Velocity/dx" and click "Select".
Now choose a name for your new variable (e.g. "Vorticity-signed"), then click "Define".
When you go to plot contours, choose "Custom Field Functions", and your new variable will be available. Note that most of the vorticity will be in the boundary layer, so you will probably have to take it off "Auto Range" and pick some lower values to see anything at all in the wake. Positive values represent rotation in one direction, negative values in the other.
Hope that helps, John
Old   March 24, 2008, 23:08
Sham
John,
Thanks a lot. It works.
Sham.
Old   May 19, 2011, 16:27
Question VORTICITY calculation in unstructured grid?
anil
anil raj is on a distinguished road
I have one doubt regarding the vorticity calculation in FLUENT. In a forum i found the vorticity calculation is by du/dy-dv/dx. But this is valid for structured mesh only according to theory and how can it be valid for unstructured grids. Is there any method (Algorithm) by which Fluent calculates the vorticity for unstructured grid?.
anil raj is offline   Reply With Quote
Old   January 9, 2016, 02:43
Rajendra Singh
rajann_786 is on a distinguished road
To, John Young
Thanks!!! It is helpful.
rajann_786 is offline   Reply With Quote
Old   May 24, 2016, 06:01
anonymous
adilio is on a distinguished road
Thank You John
I lost my 3 weeks finding how to do this.. finally you made my day
adilio is offline   Reply With Quote
Old   April 23, 2019, 05:05
mkhan
Mahram Khan is on a distinguished road
How did you define vorticity for the unstructured mesh?
Mahram Khan is offline   Reply With Quote
Old   April 23, 2019, 11:47
Lucky
The vorticity is defined mathematically the same way regardless of mesh. What differs is how you would actually go and calculate the gradient field. Fluent is an unstructured solver anyway, so it never matters. Whether your mesh is structured or not, Fluent treats it like an unstructured mesh.
Old   April 24, 2019, 00:04
mkhan
I have defined the vorticity same way and there is one built-in function for vorticity magnitude, I have compared the results and it differs on a few nodes. Can you please explain why it differs on a few nodes. Thanks!
Old   April 24, 2019, 14:05
Lucky
on notes or on cells? On nodes, there's all sorts of wonky interpolation that happens.
Old   April 25, 2019, 00:47
mkhan
Yes, it was on nodes, however, on cells it's same. Thanks!
Old   April 25, 2019, 05:35
mkhan
Can I ask you one more thing? What model is the best for 2D unsteady simulations in order to verify Navier-stokes equations? Thanks!
Flow Direction: normal to boundary!!! Atit CFX 1 August 2, 2015 13:42
Calculation of Vorticity mortain Main CFD Forum 1 July 12, 2010 04:10
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
Vorticity Iso-Surface John Main CFD Forum 0 April 4, 2009 23:10
Direction of vorticity Suvash FLUENT 2 October 16, 2005 23:41
