March 5, 2008, 06:02 |
Phase change
i have to model a problem in which water is converting into super heated steam in a pipe. how can i model it using fluent.
web links to tutorial for this types of problems are most welcome. |
March 5, 2008, 07:52 |
Re: Phase change
problem is simply.
water is entering a metalic pipe whose temperature is 800oC. through out its way, water converted in to steam and finally converted into superheated steam. i think i have explained the problem, now i want to model it in fluent, so how could i. because water change its phase into steam, so how could i incooperated this change in phase into fluent |
March 5, 2008, 09:08 |
Re: Phase change
Hi!
I have the same problem. I use the mixture/Cavitation model, but this model "lock" the pressure to the vaporization pressure, so the vapor doesn't expand, so it isn't cooling. Whith this model the water converted into steam, but doesn't cooled down. So I think, our problem is the same. Read the forum topic "phase change" below. Unfortunatly nobody answer |
March 5, 2008, 10:18 |
Re: Phase change
Well, the solution: The cavitation model isn't OK for this problem, You have to use the wet steam model.
March 5, 2008, 11:15 |
Re: Phase change
March 6, 2008, 01:06 |
Re: Phase change
thanks Robert,
i m not an expert user of fluent, so i ask u some thing more if i define the fluid properties, like change of properties with respect to temperature, should it work ?? |
March 6, 2008, 08:30 |
Re: Phase change
This is the first time, when I use this model, but I share my experience with You.
1. First calculate the flowfield with the pressure based model. Use only water or vapor fluid. So calculate a simple flowfield. 2. Switch to density based model. 3. Calculate a new solution. Note: These solutions aren't the final solutions, whit these solutions you create a better initial condition for the wet stem model. 4. Switch to wet steam model (DEfine/Models/Multiphase.../Wet steam) 5. Calculae the overheated solution. This model set the material properties AUTOMATICALLY, so you haven't need to set any properties. This model will disable the material menu, because it set everything. If you use DPM, you have to set the material of discrate hase befor switch to wet steam model. This model much slower like a "normal" multiphase models and as I see, it is very instable, so maybe you have to use smaller time step (10^-5 ; 10^-6), and maybe you have to reduce the under relaxation factors. But as I saud, I haven't got too mauch experience with this model. Bye |
March 7, 2008, 00:25 |
Re: Phase change
thanks robert, i will let u know my result after validation of out come.
Infact what i have done early to solve this problem is to define a new material using piecewise-linear and give it the properties of water then steam with respect to temperature. and then solve the unsteady solution. what do u say about this approach. ?? |
March 7, 2008, 02:36 |
Re: Phase change
#9 |
Sorry, but this approach looks bad. You defined a material, which properties "moving" on the line of water-vapor change. But the phase change strongly depending on the pressure to, not only the temperature. For example: the water boiling on 100 oC, when p=101325Pa, but if the pressure bigger, the boiling temperature is bigger, too.
March 7, 2008, 02:42 |
Re: Phase change
#10 |
Hmmm !!!!!!!!!
but when we choose a materail from fluent database, it didnt indicate any temperature or pressure for which it is takeing density, cp, visco, heat tranf coeff, etc, it takes form operating condition ?? |
March 7, 2008, 02:47 |
Re: Phase change
#11 |
23.6.2 Wet Steam Flow Equations
The wet steam is a mixture of two-phases. The primary phase is the gaseous-phase consisting of water-vapor (denoted by the subscript v) while the secondary phase is the liquid-phase consisting of condensed-water droplets (denoted by the subscript l). ( and my dear u want to model inverse, i mean here fluent assume that the primary phase is steam, but in your case it is water and i can guess that u have given the boundary condition for water ( inlet condition), so i think we should use inlet boundary condiition for outlet and vice versa plz share your view |
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 01:49 |
Phase change | phdsantos | FLUENT | 0 | March 20, 2009 10:19 |
Two phase flow with phase change | Ahmad Al-Zoubi | CFX | 1 | November 26, 2008 03:59 |
How to model the solid-fluid phase change in CFX | ohrmond | CFX | 2 | May 26, 2006 06:27 |
