grid adaptation
Old   March 6, 2008, 08:21
Default grid adaptation
Amel
Hi, I use K-E turbulent model with standard wall fonctions and I need to adapt my grid by using Y+ or Y* , my problem is that the cells in some regions are so small and they are marked for croasening but they don't change after y+ adaptation use, can you help me? thanks.
Old   March 6, 2008, 08:55
Default Re: grid adaptation
bohis
hi, it is not my cup of tea, however, Fluent may marked the original grid for coarsening and I know that the original mesh cannot be coarsed.
Old   March 6, 2008, 09:33
Amel
Thank you for your answer, but it's really illogical to have the option of coarsening and can not use it, so I will use a large cell mesh and refine it, I hope the Y+ adaptation will work in this case.
Old   March 6, 2008, 09:53
bohis
so, I was right? You have tried to coarse the parent mesh? If yes, then your problem should dissappear with using coarser mesh as parent one.
No grid adaptation Pimmie80 FLUENT 1 September 21, 2010 08:35
grid partition AND dynamic mesh adaptation !!!!!!! bohis FLUENT 0 January 16, 2009 03:00
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
floating point error during grid adaptation Nurul Murad FLUENT 2 September 5, 2001 19:15
