March 13, 2008, 05:09 |
Pressure Boundary Conditions
Dear All,
I have searched the forums already and didn't find the solution to the problem I am having. I have a simple case of a 2D channel 45mm long 9mm wide with a pressure-inlet at one end and pressure-outlet at the other. With a pressure difference of 1000Pa between inlet and outlet, the theoretical mass flow is 27kg/s. However, setting Total guage pressure at inlet to 1000Pa and total pressure at outlet to 0Pa Fluent predicts a mass flow of ~10kg/s. I understand Fluent's total pressure is a combination of hydrostatic and dynamic pressure. No gravity is involved in this simulation - it is just a pure laminar test case to validate another model but Fluent seems unable to solve. Thank-you in advance for any suggestions, Dave |
March 13, 2008, 22:15 |
Re: Pressure Boundary Conditions
You can do the follwing: 1) use velocity bc instead pressure inlet; 2) after processing, you can read the pressure value at inlet.
June 8, 2009, 17:05 |
Ravi Kapoor
Even I am getting the same problem when I use pressure conditions at the boundary and the problem seems to be resolved when I use velocity inlet at the inlet boundary condition.. Bt I am unable to explain the reason for difference in results with these two different boundary conditions? Please help. |
Pressure boundary conditions | hiras | FLUENT | 22 | July 27, 2015 01:38 |
Pressure boundary conditions | Vijay | FLUENT | 2 | January 14, 2009 12:24 |
Pressure Boundary Conditions | kantipudi | Main CFD Forum | 1 | August 10, 2008 04:07 |
Pressure boundary conditions | Lionel S. | Main CFD Forum | 1 | August 24, 2007 18:03 |
PRESSURE BOUNDARY CONDITIONS | Max MEBUG | FLUENT | 2 | August 17, 2007 00:42 |
