I have some non-positive volumes in my volume mesh. i am trying to run an inviscid simulation. Will this cause some error and will it cause Fluent to stop. Many Thanks, |
I think that you've got to review the mesh, maybe there are some curve surfaces wrong meshed. Try to look your geometry with the shade option in gambit to control if there are surfaces that look "strange"
Most problems occur because of a poorly defined initial surfaces. Check these, paying particular attention to areas of high curvature.
Are you using a prism layer? Check to see if the prism is collapsing (use smaller elements and see if the problem persists). You could try creating a mesh with no prism layer, just to see if it is boundary elements are causing the problem. Are you using TGrid or Gambit? You can use the "examine mesh" button in Gambit (the magnifying glass on the bottom right of the Gambit window) to see where the problem elements are located. Try creating finer meshes and see if the problems persist and if they occur in the same locations. In TGrid you can do the same using "display-> grid". Hope this helps. |
Could try increasing your spacing in the meshing procedure. Is your model geometrically very complicated?
Hi, I had the same problem with 3D mesh. I moved all volumes to positive axis. So, try it too.
help! how to find out the non-positive volumes? | showwa | FLUENT | 0 | August 30, 2008 02:22 |
non-positive volumes exist | DavidC | FLUENT | 2 | November 15, 2005 06:57 |
non-positive volumes | john | FLUENT | 9 | March 12, 2001 07:17 |
non-positive volumes | Javier Fernandez | FLUENT | 5 | August 29, 2000 00:37 |
non positive volumes | pankaj shukla | FLUENT | 4 | December 6, 1999 09:42 |
