Parallel Fluent on Ubuntu 7.10
Old   March 27, 2008, 15:46
Default Parallel Fluent on Ubuntu 7.10
fluentos
Hello, I've installed Fluent on a Ubuntu machine, everything works fine except that I can't start the parallel Fluent. This is the error:
Host spawning Node 0 on machine "kraken" (unix). /home/eu/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 2ddp -node -t2 -pethernet -mpi=hp -mport 127.0.1.1:127.0.1.1:38606:0 Starting /home/eu/Fluent.Inc/fluent6.3.26/multiport/mpi/lnx86/hp/bin/mpirun -np 2 /home/eu/Fluent.Inc/fluent6.3.26/lnx86/2ddp_node/fluent_mpi.6.3.26 node -mpiw hp -pic ethernet -mport 127.0.1.1:127.0.1.1:38606:0 ssh: connect to host 127.0.1.1 port 22: Connection refused mpirun: Warning one more more remote shell commands exited with non-zero status, which may indicate a remote access problem.
Thanks in advance.
Old   March 27, 2008, 18:31
Default Re: Parallel Fluent on Ubuntu 7.10
andy
use 127.0.0.1 for the connecting ip instead.
hope it works....
Old   March 27, 2008, 19:04
fluentos
Thanks Andy, it works with:
fluent 2ddp -driver x11 -t2 -ssh -cnf=127.0.0.1
Old   January 25, 2013, 07:23
jason
zhaolinchen is on a distinguished road
Hi Andy
Do you know how to set up a parallel fluent running on two machines, which installed with ubuntu 12. Mnay thanks
Jason
zhaolinchen is offline   Reply With Quote
ubuntu & fluent clash.... tamjid FLUENT 4 April 7, 2015 02:52
Fluent & Ubuntu 7.1 Charles FLUENT 6 April 1, 2008 00:13
Ubuntu 7.10 and Fluent Gibbon FLUENT 1 November 13, 2007 02:08
Fluent 6.3 on Ubuntu - doesn't work adas Siemens 3 March 24, 2007 02:03
Fluent 6.3 on Ubuntu 7.04 adas FLUENT 1 March 20, 2007 19:31
