Set up DPM before or after iterating?
Old   March 31, 2008, 14:45
Default Set up DPM before or after iterating?
John
If I want to analyze the particle tracking through a model, should the DPM settings and injections etc be set up before I go through the iterations, or does it not matter?
Thanks.
Old   March 31, 2008, 14:48
Default Re: Set up DPM before or after iterating?
John
By the way just for clarification, I'm not interested in the results "during" the simulation, rather just what they are once the system converges.
Old   March 31, 2008, 18:36
Aidan
It depends if you are interested in the interaction between the fluid and particle phase or not. If you want to model the interaction then you need to track particles during the fluid iterations. If you just want to see particles trajectories through the gas flow without interaction then you can setup injections after the simulation.
Old   March 31, 2008, 21:04
John
Perfect thanks. Yeah I just want to see how they flow in the stream, they're inert particles.
Old   April 3, 2008, 14:58
Ejaza
john is also known as ustad ejaza
Old   April 4, 2008, 01:40
amol
Hi Ejaza,
I'm simulating the secondary clarifier, in which the volume fraction of solid is to less i.e. 0.4% and i want to know the flow behaviour of the particle will u sujest me the proper guide line about the mesh and model to be used , i'm using DPM model but the paricle are distributed. is there any necessity to set the injection.
regards, amol
Iterating Naghman Khan FLUENT 2 June 19, 2007 22:01
Getting error while iterating vinod perumal FLUENT 4 March 3, 2006 17:03
Errors while iterating Vidya Raja FLUENT 5 March 2, 2006 10:26
How to cancel iterating? DAE FLUENT 0 January 13, 2004 11:55
Stop iterating DAE FLUENT 0 January 7, 2004 06:58
