Gas discharge from tank to tank through a pipe
Old   April 4, 2008, 09:06
Default Gas discharge from tank to tank through a pipe
Arno
my preliminary goal is to model the gaseous discharge of a high-pressure vessel to a low-pressure one through a thin long pipe.
The system is closed. I can't figure out how to "open the valve" at t = 0 between the high-pressure tank and the pipe. Is it an initial condition? It seems it can't be a boundary condition since I have adjacent cells around this interface (hp vessel at one side, pipe at another).
Would be pleased to get a tip for this simple (I guess) case. Thank you folks.
Old   April 7, 2008, 13:17
Default Re: Gas discharge from tank to tank through a pipe
Sasha
Hi, You could use "patch" as an alternative initialization procedure: first initialize the whole domain to, say, high pressure, and then patch a low pressure on the low pressure part of the domain. Then run the calcs. Hope it helps.
Old   September 27, 2010, 02:49
Default solution openning valve
andres
cfdhydraulic is on a distinguished road
hi friend,
I have the solution of your problem... I know is two years later but, if you already need how to open a valve, I can give you a UDF code
hugs
Originally Posted by Arno
;149678
cfdhydraulic is offline   Reply With Quote
Old   December 25, 2010, 07:05
Default UDF code
Raja
Rajaswata is on a distinguished road
Originally Posted by cfdhydraulic View Post
hi friend,
hugs
Hi CFDHydraulic
merry christmas and a happy new year
I need to UDF code
If possible please, send me.
Best regards,
Raja Swata
Rajaswata is offline   Reply With Quote
Old   December 28, 2010, 09:52
Default Req
elahe
akram is on a distinguished road
Hi, I need that udf too mate, can u plz send me? thanks in advance.
akram is offline   Reply With Quote
No sharp interface - Discharge in a pipe Matthieu Breysse FLOW-3D 5 December 10, 2009 21:18
Filling a tank or pipe stu CFX 3 May 24, 2007 18:23
SPH tank........help!!!!!!!!!! GaoRui Main CFD Forum 0 May 24, 2007 04:13
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 07:54
Emptying of a tank Mario CFX 2 September 29, 2006 10:51
