How to pass a variable from a define macro...
Old   May 29, 2008, 22:49
Default How to pass a variable from a define macro...
Padian
How to pass a variable from a define macro to another
for instance, in DEFINE_ADJUST macro, I calculat the sum of C_VOLUME under certain condition, and then I need to use the sum of C_VOLUME in DEFINE_SOURCE
Help~
Regards
Old   May 30, 2008, 05:19
Default Re: How to pass a variable from a define macro...
max
hi Padian,
you may use an external variable which should be defined at the top of your c-file and not locally within your Define-Macros.
Max
Old   May 30, 2008, 05:22
Padian
Many thanks to your help.
I have solved the problem.
Regards~
How to define a Macro accessing rad intensity Grey FLUENT 0 May 21, 2007 00:12
Why doesnbt the macro forall work for the volVectorField variable siwen OpenFOAM Running, Solving & CFD 2 February 24, 2006 15:27
field variable macro of the mean-x-velocity? zt xie FLUENT 2 November 15, 2005 05:48
define my own DEFINE macro? to model pithing naca calogero FLUENT 0 April 10, 2003 05:10
Macro/Cell-variable for incident radiation ? Vishnu FLUENT 0 April 6, 2001 23:29
