Periodic & Symmetric Boundaries
Old   June 18, 2008, 15:36
Default Periodic & Symmetric Boundaries
Marc
Hi everyone,
My current research makes use of a symmetry boundary condition down the centre of my geometry. I have now decided that I would like to make an array of my geometry, using periodic boundary conditions.
My original attempts tried to put a periodic boundary condition on one-half of my model with a symmetric boundary condition down the centre. It seems that this does not work.
I get the impression that in order to enforce periodic boundary conditions, I need to hard link faces that are opposite one-another. However, my geometry on the back face and the 'centre' is not the same and as a result, I do not want the mesh to be the same.
Is there any way around this?
Old   June 19, 2008, 14:28
Default Re: Periodic & Symmetric Boundaries
red lemon
use non conformal periodics. Can only switch on in Fluent in the TUI. Set up as interfaces then create periodics in fluent TUI.
Old   June 19, 2008, 22:56
Marc
How do I make non conformal periodics? Do I use "define/boundary conditions/modify-zones" and choose "make-periodic"?
Old   June 20, 2008, 06:04
red lemon
ok.
"grid>modify zone>make periodic" creates a conformal periodic zone.
"define>boundary conditions>modify zones>make periodic" also creates a conformal periodic zone.
"define>grid interfaces>make-periodic" creates a non conformal periodic. The faces should be of type interface first. An angle or displacement is needed here depending on whether it rotational or translational resp. I think they are then listed in the grid interfaces panel.
Gambit/Fluent only understand default "periodic zones" if they are hard linked or node matched face sets. Gambit will not allow export of a none linked face mesh set that have not been previously hard linked but defined as a periodic zone.
A single periodic zone is made up of both sets of faces.
Old   June 20, 2008, 12:26
Marc
Thanks! Having some problems with this, but I think it's on my end. Will play around with it a bit.
Old   August 30, 2012, 09:09
Default boundary condition (symmetry vs periodic doubt)
hhh
kunar
hhh is on a distinguished road
Dear friends,
i am doing 3D wing analysis, i have doubt on boundary conditions in fluent ie both symmetry and periodic, anybody have the answer please let me know briefly,for what kind of purpose to use symmetry & periodic boundary conditions, please tell any example with problem.
hhh is offline   Reply With Quote
periodic boundaries Mary FLUENT 27 January 6, 2021 01:54
transform symmetric BC in periodic BC Clementine FLUENT 2 January 17, 2008 09:48
Periodic Boundaries Christina CFX 3 December 19, 2006 11:12
periodic boundaries Steve FLUENT 0 January 27, 2005 17:25
periodic boundaries Will FLUENT 0 April 9, 2004 13:40
