LES turbulence decaying in channel
Old   July 3, 2008, 17:10
Default LES turbulence decaying in channel
cfdIsMad
Hi
I am running a channel flow using LES. My problem is that turbulence after developing for a bit starts to decay in channel. And after a while I see zero turbulence in my domain. What can I do under such circumstances to sustain the turbulence. Thank you for your answer.
Old   July 4, 2008, 12:55
Default Re: LES turbulence decaying in channel
Renato Pacheco
give more details on what you simulating. maybe I can help
Old   July 4, 2008, 13:32
cfdIsMad
Hi Renato
Thank you for your answer. I am using periodic boundary with pressure drop between inlet and outlet. I am using RANS solution as initial condition. Mesh is hexa unstructured with very low YPlus values, below 1. I have half a million cells in my grid. Courant number is 0.6 and the length of channel is 1.6m. Discretisation scheme is central difference. Thanks in advance for your help.
Old   July 4, 2008, 14:08
Renato Pacheco
ok, but when you start with RANS you have some turbulence forming and when you change to LES it dissapear? is it?
Turbulence in channel become laminar pankaj saha Main CFD Forum 1 November 9, 2010 07:16
LES turbulence decaying in channel flow cfdIsMad Main CFD Forum 6 August 21, 2009 12:17
LES turbulence decaying in channel cfdIsMad Siemens 2 July 4, 2008 08:40
LES turbulence decaying in channel flow cfdIsMad CFX 4 July 4, 2008 06:29
Stabilizing turbulence equation in channel flow Biga Main CFD Forum 5 March 22, 2005 20:06
