July 22, 2008, 01:01 |
dynamic mesh not working
I am new to dynamic mesh and I need your help. I have created simple box model which I wanted to rotate at z axis at certain rotational velocity. I want to see the outer domain mesh changes according to the rotation of the box. If this simple model works, I will use the same method to more complex model. Please check the model using these links. Full model with BCs: http://img235.imageshack.us/img235/4...is8fullfb0.png The box which is set to rotate at z axis with omega = 0.2 rad/s: http://img133.imageshack.us/img133/1...smallbozt5.png The box (solid volume) rotated, however the outer domain didnot change following the movement of the box: http://img401.imageshack.us/img401/4...rotatedfk4.jpg The box volume was rotating, as you can see from the box-shadow BC. However, the outer domain (box BC) didnot change. Can you please help me to set the case. I believe that there is something wrong with the case setting. Thanks |
July 22, 2008, 04:17 |
Re: dynamic mesh not working
You have to write a UDF to rotate the rigid box. Use DEFINE_CG_MOTION and with options such as Smoothing, Remeshing. Regards,
July 22, 2008, 05:18 |
Hi Krishna,
I am trying to write the udf file now. I am currently reading the sample for the udf with define_cg_motion. What is the symbol for omega (angular velocity)? Should we set it ourself? They only have example for force and axial velocity. I want to assign constant angular velocity to the box. At the end of certain period of time, I want to know the moment with respect to the box's cg. Thank you |
July 23, 2008, 09:00 |
I wrote this simple udf file to rotate the box at z axis with omega = 0.2 rad/s. #include "udf.h" DEFINE_CG_MOTION(boxtwo,dt,vel,omega,time,dtime) { /* reset velocities */ NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); if (!Data_Valid_P()) return; omega[2] = 0.2; } Then when I tried to attach it to the box (volume), I got this error message. Can somebody please show me where is the error. Warning: incorrect cg motion UDF boxtwo on zone 2 (assuming no motion) Thank you |
July 24, 2008, 03:31 |
keep the mesh file and the udf in the same directory. you have to load the file in to the solver by using compile option. DEFINE->USER-DEFINED->FUNCTIONS->COMPILE->udf.c and built and load it. You may have problems if you do not have a C compiler. Better load VC++ if you are working on windows operating system. ReGARDS,
Dynamic Mesh | Pj | FLUENT | 1 | March 12, 2007 15:16 |
Help: Basic steps to get dynamic mesh working | CH | FLUENT | 4 | November 6, 2006 09:38 |
dynamic mesh - structured or cooper mesh | Manoj Kumar | FLUENT | 2 | November 11, 2005 01:18 |
dynamic mesh and sliding mesh | nasser | FLUENT | 0 | November 1, 2005 02:37 |
dynamic mesh | sam | FLUENT | 0 | November 1, 2004 23:16 |
