GAMBIT - Creating and meshing face by sweeping
Old   July 23, 2008, 06:15
Default GAMBIT - Creating and meshing face by sweeping
Woo Meng Wai
Dear all,
I am facing a problem in quad meshing the side wall of a cylinder. How I intended to create and mesh the side of the cylinder at the same time is as follows:
1. create a circular edge 2. at one of the points used to define the circular edge, create a straight edge down (perpendicular to the circle) 3. mesh both circular and straight edges 4. sweep the circular edge down along the straight edge
While the vertical lines of the mesh generated follows that of the meshed circular edged, the horizontal lines do not follow the edge mesh of the straight edge. Instead, larger intervals were automatically used.
Why is this happening? What can be done?
Best regards, Woo
Old   July 23, 2008, 07:43
Default Re: GAMBIT - Creating and meshing face by sweeping
mAx
Create first your volume. The mesh one of the disk (source face), then mesh the cylinder face. Make sur that this face is mapple. If your geometry is clean, Gambit should automatically recongnize this volume as Cooper
Old   July 23, 2008, 07:51
Woo Meng Wai
Thank you for responding. I am actually trying to mesh the face first before usign cooper. this is because we would like the height of the mesh to be getting progressively smaler towards teh bottom of the cylinder (grading on the height of the mesh oward the bottom). Any idea?
Best regards, Woo
Old   July 23, 2008, 08:17
mAx
you can't mesh a surface with cooper. Mesh it with quad-pave. For your growing mesh (volume), use Size Function
Gambit error creating face Haridas Attur Main CFD Forum 1 February 17, 2009 03:31
Re:Creating a Face in gambit Fatou FLUENT 3 November 2, 2005 08:24
Gambit face meshing with a common edge stella FLUENT 1 October 28, 2005 05:09
creating a face patrick FLUENT 1 May 6, 2004 09:24
Creating geometry & meshing using Gambit Ray FLUENT 3 August 1, 2000 03:30
