A Simple question about Nusselt No.?!
Old   July 26, 2008, 06:39
Default A Simple question about Nusselt No.?!
Yalu
Dear All,
I am a new user of Fluent. I need to calculate Average value of Nusselt No. for an internal flow in a pipe with constant heat flux. I have checked the calculation with Report > Surface Integrals> area-weighted average> surface heat transfer coefficient : & Nu=(h*d)/k; using wall average Static Temperature and pipe area and diameter in reference values. But unfortunately the results are so different with literature, especially when changing the Re. No. The length of the pipe is 0.8 m & the diameter is : 0.01m.
Any urgent help would be appreciated.
All the best:Yalu
Old   July 26, 2008, 08:50
Default Re: A Simple question about Nusselt No.?!
AAA
Hi
Check the fluid properties (k). The mesh at the wall has to be fine enough.
regards
AAA
Old   July 28, 2008, 07:22
Yalu
Dear AAA, Thanks alot for your prompt answer. I checked the properties.They are O.K. Also about the mesh I have used 100*150 grid: 100 in r-direction and 150 in x-direction.? I think it suits with my dimension. Anyway I would like to know is there any reliable procedure for calculating Average Nusselt number, which consists with literature? I look forward to hear from anybody who can help me....
Best Wishes
Old   July 28, 2008, 16:24
deepthi saini
hi,
for calculation of nusselt number .Follow this procedure.
STEP 1 as you are modeling a constant heat flux problem use newtons law of cooling to calculate nusselt number
STEP2
i.e; q=h (TS-TF)
ONCE h IS OBTAINED
then use h to calualte Nu =hD/K
your solution doesnt match the analytical solution as fluent uses length to calculate Nusselt number so foolow this steps These will help IF YOU NEED ANY OTHER HELP YOU ARE WELCOME BYE GOOD LUCK
Old   August 19, 2008, 05:15
Yalu
Thanks a lot for your answers, but can you help me how to find TS and TF (wall temperature & fluid temperature) from FLUENT?
All the Best
Old   August 21, 2008, 22:26
deepthi saini
hi
sure i can help you
you can plot wall temperature using the icon plot-xy plot-
and select your boundary wall to get the surface temperatures at each point
step 2
click on write option in the same panel /store in excel file
for fluid temperature
go to mass weighted average in surface integral option and select outlet if you need outlet fluid temperature
but if in case you need the average fluid temperature or all the temperature along the tube
you need to create vertical lines/rakes in the tube using surface -point option /line option in fluent
after creating lines calculate the same mass weighted average along that lines using surface integral option
this gives the fluid temperatures along the flow.
good luck seems lengthy but this wil work
bye
a simple question Al Mazdeh CFX 2 February 18, 2008 14:48
I think simple question mneo FLUENT 1 April 13, 2004 05:33
simple question noName Main CFD Forum 1 April 11, 2004 08:29
some simple question,please help ann FLUENT 4 December 11, 2002 01:09
a simple question Marty Main CFD Forum 4 May 18, 1999 09:40
