2D periodic from ICEM to FLUENT
Old   August 6, 2008, 13:38
Default 2D periodic from ICEM to FLUENT
Markus
Hey all,
I have a problem when loading a ICEM mesh into Fluent, It is a 2D tranlational periodic grid.
I get the following error:
Building...
grid,
Warning: Inappropriate zone type (periodic) for one-sided face zone 15. Changing to wall. Warning: Inappropriate zone type (periodic) for one-sided face zone 16. Changing to wall.
Error: FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
I can't seem to get it right...
Any ideas on what i might be doing wrong? I set the periodicity in ICEM and the periodicity check tells me there are no problems.
Hopefully someone can shed some light on this.
Thanks!
Markus
Old   August 11, 2008, 07:13
Default Re: 2D periodic from ICEM to FLUENT
Markus
I actually managed to correct that error, by redefining the periodic zones in fluent with the grid/modify-zones/make-periodic command. Somehow the ICEM export seems to mess up the periodic definition, or I might be doing something wrong there.
ICEM periodic boundary CG CHEN CFX 6 October 11, 2011 02:56
Periodic cut surfaces - ICEM? Jane CFX 0 May 18, 2008 20:55
ICEM periodic boundary Chungang CHEN CFX 1 August 15, 2007 05:11
ICEM PERIODIC TURBOMACHINE august CFX 2 February 20, 2007 22:22
Periodic faces in ICEM/HEXA Alexey CFX 1 May 4, 2006 08:58
