Periodic boundary conditions
Old   August 14, 2008, 12:08
Default Periodic boundary conditions
happy5jump
Hi everyone,
I'm modling a 360 degrees cylinder
I just want to use a 9 degrees slide to simulate the whole geometry.
I set the left and right walls as periodic boundaries.
Now I have two Questions:
1. how to set periodic boundary condition in FLUENT? There's no help in FLUENT about periodic boundary....
2. What does this periodic boundary condition mean?
Is there any relation with the calculation?
Does periodic boundary mean it can simulate the real whole geometry?
Thanks
Old   August 14, 2008, 17:09
Default Re: Periodic boundary conditions
red lemon
Both face sets represent the entire single periodic zone. Use the TUI command Grid>modify zone>make-periodic to create and slit periodic to remove. A periodic means flow through one face comes out of the other. For a regular periodic like turbo cases you need not set anything such as dP or flow in Define>periodics in the GUI. Fluent and Gambit see default periodics as conformal face sets but you can in fact define non conformal periodics using define>grid interface>make periodics. Hope that helps!
Old   August 14, 2008, 18:18
happy5jump
Thanks!
One more thing I want to know is
This is a 40 inlets geometry Can I just use 1 inlet ,1 outlet, and periodic boundary condition to samulate the whole geometry?
Old   August 18, 2008, 00:39
mAx
yes you can use only one inlet one your 9deg slice. But regarding the mesh, your both periodic faces have to be linked (eg: same mesh) Gambit won't you allow to set them as periodic if the surface meshes aren't the same.
Old   November 17, 2012, 19:34
Default help in periodic
fares
fares is on a distinguished road
I have the same problem I want to make the two opp walls at the inlet and outlet of a blade passage to be periodic how can i do so? in fluent 14
fares is offline   Reply With Quote
Old   January 29, 2013, 16:06
Mohammad A. Hossain
mhossain is on a distinguished road
Originally Posted by red lemon
;152809
I have a problem defining the periodic BC in FLUENT. I am simulating a wind turbine blade with one blade and 120 degree domain. but while I apply periodic BC in TUI , I got an error massage that main face and shadow face does not have same number of elements. one of my wall have 465 faces and the corresponding shadow face has 510 face.
How can I fix this problem? Is there any way to fix this problem in FLUENT ? I truly appreciate your suggestions.
Arif
mhossain is offline   Reply With Quote
Old   May 3, 2017, 00:36
kshitiz
kshitiz is on a distinguished road
I am late but if you guys are wondering about the translational periodic boundary condition i have a solution.
If you have a asymmetric geometry then before you run Make-periodic code in fluent you have to use a mesh match control to make equal number of mesh in adjacent faces.
But while using mesh match control be sure to use arbitrary transformation.
Thanks hope its helps
kshitiz is offline   Reply With Quote
PERIODIC BOUNDARY CONDITIONS P.R.NAREN FLUENT 1 May 14, 2005 12:51
Periodic Boundary Conditions ! Krik FLUENT 1 March 22, 2005 18:50
periodic boundary conditions Satish Perivilli FLUENT 0 January 28, 2005 11:54
Periodic Boundary Conditions+NSE Isa Main CFD Forum 1 December 20, 2003 07:03
