September 6, 2008, 08:36 |
out of memory
i haven't changed my system settings.when i try to access my saved case & data files,i get 'out of memory' messgae.what can be the reason?
September 6, 2008, 12:53 |
Re: out of memory
thumb rule is for 1 million cells...1 GB Ram..if your system does not have that it may occur..please check.
September 6, 2008, 23:49 |
Re: out of memory
thanks.i have 512kB memory & could use fluent for many days.why with the same system configuartion i am gettion this problem?
September 7, 2008, 02:05 |
Re: out of memory
perhaps you have saved the data in C:\ route! check it out.
September 7, 2008, 09:24 |
Re: out of memory
thanks for help.yes.i have saved there only.pl advise what to do.
September 7, 2008, 09:32 |
Re: out of memory
well maybe thats because you do not have enough memory on c:\ drive. try saving data in another drive. because for the memory allocation etc., the system uses the available memory on C: route too!
September 7, 2008, 10:10 |
Re: out of memory
I get follwing error. #Reading "D:\CASE&DATA\saneH126050.cas"... 291840 hexahedral cells, zone 2, binary.
3432 quadrilateral pressure-inlet faces, zone 3, binary. 97128 quadrilateral symmetry faces, zone 4, binary. 996 quadrilateral interior faces, zone 5, binary. 384 quadrilateral wall faces, zone 6, binary. 2432 quadrilateral wall faces, zone 7, binary. 822836 quadrilateral interior faces, zone 9, binary. 344043 nodes, binary. 344043 node flags, binary. Building... grid, Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc node, size 13165376, t 9, myid 1000000.# Pl help. |
September 19, 2008, 10:20 |
Re: out of memory
You can buy 1GB memory for about 20-30 $ today. It will probably solves your problem and also allow you to refine your mesh, if need.
Memory | Christian Cordeiro | CFX | 11 | May 25, 2016 22:52 |
Out of memory? | raintung | FLUENT | 6 | May 25, 2016 22:21 |
RAM memory | alpha | CFX | 1 | October 8, 2009 11:31 |
Out of Memory | Naghman Khan | FLUENT | 3 | August 30, 2007 06:08 |
Memory 400-667 MHz | George | Main CFD Forum | 8 | March 1, 2007 08:22 |
