fluent installation error
Old   September 24, 2008, 05:08
Default fluent installation error
Ramesh.K
I would appreciate to get help form people who konw how to set the environment variable in linux
I am getting the following error Error: directory /usr/local/Fluent.Inc/fluent6.3.26 does not contain a valid arch. Set the environment variable FLUENT_ARCH and try again.
I am using a 64 bit machine hp laptop and the os is ubuntu 8,0
I request you to help me out in fixing this
Old   September 25, 2008, 19:31
Default Re: fluent installation error
chule
may yo must to set the valid architecture for your instalation--try with: (in terminal, move to /usr/local/Fluent.Inc/bin/) $ FLUENT_ARCH=lnamd64 fluent
good luck!
Old   September 25, 2008, 20:58
Ramesh.K
Hi Thanks for the reply. I have tried the option but it did not work.
I am using linux 32 bit version in 64 bit machine and os do u think it will work I am getting the same error
I did as u told went to the /usr/local/Fluent.Inc/bin floder and wrote this command FLUENT_ARCH =lnamd64 and export FLUENT_ARCH
but after that also it gives me the same error
/usr/local/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 Error: directory /usr/local/Fluent.Inc/fluent6.3.26 does not contain a valid arch. Set the environment variable FLUENT_ARCH and try again.
thanks for any sort of help
am using ubuntu latest version with kde 3.5on intel with core 2 duo 2.26 ghz 8400 processor
OF15dev installation error velan OpenFOAM Installation 11 February 13, 2009 09:23
Installation error sukratu OpenFOAM Installation 6 September 16, 2007 22:46
Error after installation.. Nari Siemens 5 June 28, 2007 14:02
Installation Error rafal OpenFOAM Installation 3 February 2, 2006 11:43
Fluent 6.2.16 installation with Error EOF tuks FLUENT 3 July 13, 2005 13:20
