Surface Integral - Mass Flow Rate
Old   October 6, 2008, 10:36
Default Surface Integral - Mass Flow Rate
Venkatesh V
Hi All,
I am I have created a plane using Surface -> Plane. ( it create plane-19) But when I check the mass flow rate in using surface integral on that it gives some mass flow rate which is different from the mass entering the domain.
The results look resonable. Did any one has come across similar issue and any solution ?
Old   October 10, 2008, 07:06
Default Re: Surface Integral - Mass Flow Rate
Prasad
This issue is not uncommon. Please specify how much is the difference between mass flow rates across the two surfaces.
Old   October 10, 2008, 07:22
Venkatesh V
The differnce is close to 200% to 300%
Old   October 10, 2008, 16:18
Prasad
This difference is definitely not within acceptable limits (a percent or two). Error lies either in surface creation (check coordinates) or in solution (converged?/correct models).
Mass flow rate of the DPM mass sourse ?? Rhinocao FLUENT 3 January 21, 2011 12:10
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 09:29
Mass Flow Rate on the Interior Surface Barii.Johnason FLUENT 24 May 11, 2007 17:59
monitor surface integral & report surface integral Ning FLUENT 0 March 18, 2007 12:51
How are the mass flux and mass flow rate defined? Miles Siemens 2 November 7, 2002 08:45
