October 7, 2008, 11:31 |
how to simulate exchanger?
my model is: the hot-water pipe has small diameter (inner) , and the cold-water pipe has big diameter (outer). the heat tranfer from the hot-water through the steel pipe to the cold-water. boundary condition: (1)fliud1 (hot-water): velocity-inlet(0.1m/s) , outflow , T=640K (2)fliud2 (cold-water): velocity-inlet (0.1m/s), outflow , T=610K (3)solid : steel (4)wall (outside of cold-water pipe ): heat flux=0 because the Re<2300 , the problem is a liminar flow. the model seems no error i think. however, the reslut is dispointed me. the residual is always flat and very large;the cold water flow incorrect. i don't kown why it is , and i guess two reasons: (1) the model set has mistake or (2) fluent is not excellent to simulate this kind of problem which is the soild and fluid heat transfer couping
October 8, 2008, 09:59 |
Re: how to simulate exchanger?
What residual?, energy residual? If you wan heat transfer occured in this model, you have to beware on the boundary wall between two difference material " Shell boundary" where the konduction or convetion constant need to be stated. You also have to turn on the energy solver.
October 9, 2008, 07:39 |
i have already turned on the energy solver
How to simulate Plate Heat Exchanger | Summer | FLUENT | 4 | February 17, 2022 01:37 |
HOW TO DESIGN AND SIMULATE HEAT EXCHANGER... | fadly | CFX | 1 | August 14, 2007 15:40 |
How to simulate 3D shell and Tube heat Exchanger | san | FLUENT | 2 | February 22, 2006 05:44 |
How to simulate mass transfer in heat exchanger? | Yang Bin | FLUENT | 0 | January 17, 2005 06:35 |
Heat exchanger | mkiku | FLUENT | 1 | July 21, 2004 09:53 |
