October 21, 2008, 05:53 |
How to model fluid-porous interface
The fluid-porous interface boundary is difficult to set. The flow from the fluid layer cannot enter the porous layer no matter how I try. I have tried defining the boundary as "internal", "interior" or "interface", but it just doesn't work. What type of boundary is suitable? There is a function in Fluent called "grid interface", do I need to set them for fluid-porous interface? How can I set it? thanks. |
October 21, 2008, 09:38 |
Re: How to model fluid-porous interface
Grid interface is only to use if you have two parts of a geometry which are not connected (only one adjacent fluid zone per interface side - but two coincident boundaries). If you can set a internal boundary (shared by two fluid zones) as "interior" it can not be used as an interface.
Are there any error messages when you define the boundary as interface/interior...? |
October 22, 2008, 01:02 |
Hi CFD Friends,
I too have an some doubts related to interface colud u pls help me so that i wil be so gratefull to u. Pls can u give me ur mail id, so that i ask my queries friend. With regards, Raghu |
October 22, 2008, 01:03 |
Thanks Grisu,
I managed to model it with interior now. Do you ever use UDF to solve the solid temperature of porous medium? If you have, could you share with me a small or simple example? My porous medium has permeability, K = 9.13e-8, therefore, the viscous resistance, D=1/K= 1.1e+7 with this viscous resistance, the flow in a fluid domain cannot enter the porous domain at all, I just wonder my computation is correct. If I reduce the value of D, then the fluid manage to enter the porous medium. however, practically, it suppose to enter even with D=1/K= 1.1e+7. Thanx |
October 22, 2008, 03:02 |
Yoshi,
sorry - I have not used an UDF for this so far. How is the shape of the flow domain - has the fluid the possibility to bypass/avoid the porous zone? If so, the resistance seems to be high enough to block the fluid (in reality of course you have capillarity effects, which are not included in the porous zone model). |
October 22, 2008, 04:52 |
Raghu,
my email: wongkokcheong @ hotmail.com |
October 23, 2008, 09:54 |
Grisu,
It a horizontal channel with jet inlet at the top. Then partically filled with a porous medium. The flow will somehow hit the porous medium.. |
fluid-porous interface | strider | CFX | 6 | October 22, 2023 18:47 |
Radiation on fluid-porous interface | DanR | CFX | 1 | November 26, 2008 10:28 |
How to model fluid flow through porous material | Ram Dayal | CFX | 4 | September 17, 2006 01:28 |
Heat transfer for fluid-fluid interface | lentil | FLUENT | 0 | March 31, 2005 15:25 |
interface between porous and fluid | rajesh kumar | FLUENT | 5 | October 22, 2004 11:10 |
