Eddy viscosity formulation
Old   November 7, 2008, 08:16
Default Eddy viscosity formulation
Raja
Dear all, I found the formula for Eddy viscosity in FLUENT manual is
DENSITY * C * KineticEnergy*KineticEnergy / DissipationRate.
Constant C=0.09
But, in another literature for the same Standard K-E turbulence model, they have not including the Density in the above expression. In which case this formula will differ ??
If you see the following link, here, they have not included the Density part. http://w3.gre.ac.uk/~physica/phy3.00/theory/node152.htm
Kindly provide the clear idea regarding this issue. Thank you very much Raja...
Old   November 7, 2008, 08:57
Default Re: Eddy viscosity formulation
Pascal
Hi Raja,
I havent read the Fluent manual, but I guess Fluent is not wrong, and the article neither!
I would use the definition of your article, this is the one I have learnt. I guess it is just that in Fluent manual, they don't use rho as a factor in the equation and use it for each term.
Just check that K and e equation are the same in Fluent manual and in your article (or in your course notes) for your understanding.
Old   November 7, 2008, 09:57
Friend
That is because the kinetic energy in Fluent is defined per unit mass. You need to cross check that as in the end they should be having similar unit.
Old   November 8, 2008, 05:59
Raja
Hi Pascal, thank you very much for your guidence. Yes, what you said is right. In, K and E equations, they(FLUENT) have included Density term, where as in my work, we have not included the Density term. Again, thank you very much.
Raja
Old   November 11, 2008, 04:32
Rami
The link you supplied uses the kinematic viscosity. Maybe FLUENT reference uses dynamic viscosity?
Eddy viscosity formulation Raja FLUENT 0 November 7, 2008 08:16
eddy viscosity Mike CFX 1 April 4, 2006 13:12
Eddy Viscosity Murthy Main CFD Forum 15 November 30, 2005 05:11
Eddy Viscosity ashish CFX 0 July 20, 2005 04:19
about eddy viscosity :UDF sagga FLUENT 2 January 10, 2005 21:07
