UDF query
Old   December 15, 2008, 04:06
Default UDF query
carno
I am using DEFINE_CG_MOTION udf in one of my problem. Is it possible to use the same UDF two times? Means if I use following syntax what will happen?
DEFINE_CG_MOTION(piston,.........) a a a a DEFINE_CG_MOTION(Cylinder,........) b b b b DEFINE_CG_MOTION(piston,.........) c c c c
Note that I am using "DEFINE_CG_MOTION(piston,.........)" two times and I want output of second as final one. I using this because some output from first 'piston' is used in 'cylinder' and 'cylinder' output is used in second 'piston' UDF. All the three UDFs use geometry so I need to repeat UDFs without changing name ('piston')
IS it right?
Old   December 16, 2008, 19:16
Default Re: UDF query
Davy
You may not use the same name twice if you put them into the same library.
FSI query CC CFX 2 September 1, 2008 01:31
MRF query sandip FLUENT 3 July 4, 2008 05:17
DPM query DPM_fluent_user FLUENT 0 June 23, 2008 12:13
query rajesh kumar gupta FLUENT 0 October 9, 2007 17:44
Query Andy FLUENT 3 January 31, 2006 01:48
