Need help about LES
Old   January 21, 2009, 10:36
Default Need help about LES
Shafayat
Hi, How do I recover interim values of different parameters after running the simulation (LES) for some time. Like i have run it for 250 sec with 0.25 sec step. But how do i know the value of velocity after 100 sec or 150 sec?
Thanks for your help.
Shafayat
Old   January 22, 2009, 01:42
Default Re: Need help about LES
zongtwi
Use File>Write>Autosave to save your results for each timestep of flow time accordingly. Then post process your results as you normally would.
Hope that helps.
