August 7, 2012, 10:00 |
#21 | |
MINNESOTA
Hi MAX
Thank you for your help. Could you please tell me where I should write a profile, actually I'm getting confused, Should I create through define profile option in Fluent or I can creat by myself in a text format and then saved it and uploading it in fluent? Thank you so much.. Quote:
August 8, 2012, 00:33 |
#22 |
Maxime Perelli
Rep Power: 41 |
in 6.3 you could create your profile as text file, or also in Fluent
In memory of my friend Hervé: CFD engineer & freerider |
March 2, 2013, 22:04 |
Udf
#23 |
Rep Power: 13 |
I need the UDF
July 3, 2013, 08:49 |
#24 |
Victor
Rep Power: 13 |
Hello.
I have simulation divided into two steps. To set a boundary condition as transient profile in second step i need to write this transient profile during calculation of first step. Or may be i can compose this profile, using resulting .dat files? But i can't find how to do it automatically. I know how to write simple profile (x y z parameter1 parameter2) but it is not transient. It is very hard to open all dat files and save profiles and then compose full transient profile. Thank in advance for all help. |
March 24, 2014, 04:15 |
profile file doubt
#25 |
amit
Rep Power: 12 |
there is a good help on this thread, but i have a doubt
if my simulation has run for 1000s and now i want to change my pressure outlet BC by giving a profile should my first point be pressure at 1000s or i should start from 0. |
March 24, 2014, 05:52 |
#26 | |
Victor
Rep Power: 13 |
time 1000 2000 3000 pressure 500 700 1300 or like this if your BC was steady time 0 999 1000 2000 3000 pressure 30 30 500 700 1300 and you can continue your calculation. But problem is in difference between your outlet bc until moment 1000s and after. If difference is significany it may be a problem. |
March 24, 2014, 05:55 |
#27 |
amit
Rep Power: 12 |
i got the answer, thank you very much.
August 9, 2015, 14:56 |
Coordinates
#28 |
Christian Mahr
Rep Power: 10 |
Hi everybody,
I am facing a problem including pofiles as well. I managed to create a .prof file in the correct format where I put velocity magnitudes for the use as a velocity-inlet profile. As it is a point profile, I have to give it the point-coordinates. To which coordinate system does it refer?! my geometry is kind of complex so the points are situated somewhere I dont really know about coordinatewise, reffering to the global coordinate system. can I read specific coordinates out of the geometry?! all the best,christian |
October 29, 2016, 15:24 |
help wanted
#29 |
mike
Hi there,
I am fairly new to ansys fluent and I need to create a tabular transient profile for a two phase flow system with fuel vapor going into a cylinder from a very small inlet. The velocity profile of the fuel is not constant as it needs to create vortex rings so adjusting for time will be the easiest way to do it. however i don't understand all the aspects to the table form and my first try at making this table does not seem to show on user defined profiles for inlet after i read the profile. my transient table looks like this so far inlet 2 6 0 time velocity 0.1 0.0000008 0.2 0.0000800 0.3 0.0080000 0.4 0.8000000 0.5 0.0008000 0.6 0.0000008 (could someone also please explain what these 3 numbers next to the profile inlet is meant to represent, i know this may seem like a stupid question but have my own interpretations and i could easily be wrong) Would this table be sufficient for two phase flow (correct format excluding the brackets)or would i have to add something extra to specify which phase this will apply to. Also could someone please instruct me on how to read this on ansys from notepad, i tried using the text command to read transient table and ansys says its reading file but nothing happens, any advice? Any help will be appreciated. |
December 6, 2016, 07:02 |
#30 |
Onur Özcan
Rep Power: 12 |
how can we create unsteady tabular boundary conditions?
I could not see anywhere to write it? time velocity 0 5 3 0 6 5 9 0 12 5 ... going on so, |
April 30, 2017, 09:20 |
#31 | |
Sadia
Rep Power: 9 |
Can you please post a complete example of udf starting from the first step (#include "udf.h") till last step i.e. (end_f_loop(f,t) }) using tabular transient udf. Thanks in advance! |
May 6, 2017, 04:28 |
#32 | |
Sadia
Rep Power: 9 |
May 7, 2017, 04:18 |
Transient 3D for finite volume methods
#33 |
Sahidah Grozny
Assalamualaikum wr. wb
good morning, i've problem in formula numerical analysis for my script? if my (simulation) condition is 3D Transient at cylindrical pipe 3/4 inch. thanks before, Have a good activity guys. SG |
September 27, 2017, 08:54 |
Reading Transient Tables
#34 |
Ujwal Rajan
Rep Power: 8 |
Hey guys,
I am using fluent and matlab to run a fluid structure interaction over an airfoil. I am making use of matlab to feed all the commands into fluent and perform the necessary actions. I have to input the profile for a gust of wind at the inlet (which is a pressure-farfield) in my case. i have used the following command in matlab to input the gust: fprintf(fid,'(ti-menu-load-string "file interpolate read-transient-table " " \\n")\n'); However, i do not know what to fill in after using the command read-transient table. Also, how do i specify on what zone the profile has to be used in?? Any help is massively appreciated! Thank you! |
July 29, 2019, 16:35 |
#35 |
Abdullah Tariq
Rep Power: 8 |
Hi, I am also trying to use a transient tables to apply my boundary condition. However when I type in the following commands into the ansys console
file /file>read-transient-table transient-table file name [] (insert name) ANSYS displays the error shown below. I made file on wordpad using the correct format and saved with txt extension. I saved the file to my desktop. Can you help me with this? Error: File "insert name" not found! Error Object: #f |
Getting Time Series data from saved unsteady data | Atul | FLUENT | 4 | November 26, 2008 05:12 |
applying profile data as a boundary condition | vadivel | CFX | 1 | June 9, 2007 07:11 |
file/write-profile ... journal file | MM | FLUENT | 5 | November 30, 2006 03:07 |
2D setup and 2D profile data file in CFX10 | Se-Hee | CFX | 3 | October 30, 2006 09:49 |
Profile Data Velocity Boundary Condition Changes?? | Maria Angelica | CFX | 9 | June 14, 2006 02:44 |
