Cooper meshing error: intersecting edge
Old   February 23, 2009, 20:06
Default Cooper meshing error: intersecting edge
Stuart
I'm attempting to mesh a volume using the Cooper scheme. It's basically a tube with detailed ends (mostly mapped, but a couple of paved faces). It's been meshed successfully before using Cooper, but I've had to split a connected volume, splitting a couple of the 'side' faces. I've re-meshed the edges running along the length of the volume, either side of the new split, and even got the side faces re-meshed using a Map scheme.
When attempting to re-mesh the volume, I get an error:
"Error: Projection intersection attempted without any free nodes on the intersecting edge. Volume volume.80 could not be meshed."
Any clues on what I need to look at/do to get this volume meshed again?
Many thanks in advance.
Stuart
Old   February 23, 2009, 20:11
Default Re: Cooper meshing error: intersecting edge
Stuart
I'm using Gambit 2.4.6 by the way, if that makes any difference.
Old   February 24, 2009, 10:27
Ralf Schmidt
Hi!
I did not really get the geometry of your problem...
However, what I do when I want to create a cooper mesh is the following:
1. create the source face solo, without any volume. And mesh that face as you want.
2. create an edge, that corresponds to the third dimension of the volume (attached to one vertices of the source face)
3. mesh the edge with the mesh line tool
3. in volume commands, use the "sweep face" command and sweep the face along the edge, the button "with mesh" must be turned on!!
4. you gut your volume! -(you ma delete that edge)
Best wishes Ralf
Old   February 24, 2009, 10:31
Ralf Schmidt
Hi!
4. in volume commands, use the "sweep face" command and sweep the face along the edge, the button "with mesh" must be turned on!!
5. you got your volume! -(you may delete that edge)
Best wishes Ralf
Old   February 26, 2009, 06:20
Stuart Barlow
Thanks for the advice. Unfortunately I'm working with imported CAD geometry, the volume was created by splitting an existing one with swept surfaces of the outline of the new one... never again CAD!
Old   February 26, 2009, 06:46
Ralf Schmidt
Hi
ok.. another idea:
you may pre-mesh the side faces of you volume. Either with mapping scheme... or with Quat/Tir option.
That may help...
Ralf
Edge meshing kpv CFX 4 May 15, 2009 04:56
cooper mesh error Selina FLUENT 0 March 7, 2009 07:01
Meshing for Edge Charles Main CFD Forum 0 October 25, 2008 10:07
IMPRINT COMMAND IN COOPER MESHING SCHEME TINA FLUENT 3 October 7, 2006 05:03
Error message on Cooper scheme mesh Mnu & Luc FLUENT 1 January 20, 2003 05:56
