Can Fluent perform evaporation and condensation simulation?
Like Tree9Likes
Old   February 24, 2009, 08:13
Default Can Fluent perform evaporation and condensation simulation?
Wei Shao
I am new in Fluent. Can anyone tell me if Fluent can simulate evaporation and condensation of water in a pipe? I would appreciate it if anyone can help me! Thanks a lot!
adelbaew, alex_gtz and vats1994 like this.
Old   February 24, 2009, 16:51
Default Re: evaporation and condensation simulation for he
Pablo
of course it can, read fluent user's guide
Old   February 25, 2009, 08:55
Wei Shao
Really? Can Fluent simulate two phase flow in a pipe and track the interface between liquid and vapor and discontinuity through the interface?
Old   February 25, 2009, 09:44
Pablo
see VOF model
Old   February 25, 2009, 09:50
Wei Shao
Thnanks a lot!
Old   February 27, 2009, 12:23
Wei Shao
I am really not familiar with Fluent, Could you please recommend some references which did similar problem?
Thanks a lot!
Old   November 28, 2011, 01:26
Syed fakhar abbas
radiation.boy is on a distinguished road
Use evaporation condensation model in Fluent 12.1 ... u will see it when u activate mixture model and in phases click on interaction button... there u vl open a page with many tabs .. click on mass tab and u vl open a window in which u can give number of mass transfer mechanisms ... by defualt it vl be zero change it to one and den select from mass transfer mechanism condensation evaporation model and den give ur saturation temperature and frequency of evaporation and condensation datz all...
chaitanyaarige and 6863523 like this.
radiation.boy is offline   Reply With Quote
Old   February 2, 2012, 19:16
maria jesus
Maria Jesus is on a distinguished road
hi.
I'm new in fluent.
i'm working in a model with water evaporation, but i can't understand the "saturation temperature" idea, because the temperature change a lot when i use it...
Could someone help me with that concept, please.
Thanks.
Maria Jesus is offline   Reply With Quote
Old   February 9, 2012, 01:16
Syed fakhar abbas
Originally Posted by Maria Jesus View Post
hi.
I'm new in fluent.
Thanks.
U have tio analyze the temprature and pressure decrement rate and then accoding to these value u have to define a udf for saturtion tempteraure... if u dont know the temp and press decreamemnt rate then u have to assume it ok
Old   May 17, 2012, 21:13
Song Wenyu
foolstop is on a distinguished road
hi, did you use the vof model successfully simulate the process of condensation? what's your results? and any condensation phenomenon occur?
foolstop is offline   Reply With Quote
Old   December 28, 2012, 11:36
Default Evaporation Boundary Condition
  #11
Dariush53 is on a distinguished road
In my work I need to simulate evaporation for boundary condiation.
I am not familiar with fluent completely.
I have one questaion about setting Evaporation for boundary condiation in fluent, how I can simulate Evaporation for one of Boundary Condiations.
I don't want to use multiphase, I want only to Set Evaporation for Boundary Condiation.
I will be appricated, if someone can help me in this way .
Dariush53 is offline   Reply With Quote
Old   January 1, 2013, 21:59
maria jesus
Dear Dariush:
I'm going to asume that you are working over the pond and a constant temperature. So, if that's the matter, then you need to put de absolute humidity as Relative Humidity at 100% in that boundary.
I hope thats work OK.
Old   June 25, 2013, 17:01
Default Frequency in evaporation-condensation model
  #13
Anna
Annananana is on a distinguished road
Send a message via Skype™ to Annananana
Hi!
Im totaly new in ansys Fluent. I've started with modeling evaporation and condensation. But I absolutely cannot understand evaporation and condensation frequencies. What are they and how should one set them. I''ve red Help about this model, but there's not a word about these frequencies. There is an accommodation coefficient, but it is for condensation and it is not frequency. Maybe they are connected somehow with evaporation/condensation velocities?
I'd really appreciate it, if you could help me.
Thank you very much.
Anna
6863523 likes this.
Annananana is offline   Reply With Quote
Old   July 1, 2013, 06:39
Gimlas is on a distinguished road
On the contrary, Users manual clearly states that evaporation and condensation frequencies are purely empirical factors. The problem is that you have to guess these values in order to fit the simulation results to the experimental data.
Gimlas is offline   Reply With Quote
Old   July 1, 2013, 08:02
Anna
Dear Gimlas,
thank you very much. Could You possibly point where it is written in Help more detailed. I read it in 16.7.5 Evaporation-Condensation Model, and there I found only this "By default, the coefficient for both evaporation and condensation is 0.1."
Again thank You very much for the answer.
Anna.
Old   July 2, 2013, 10:23
Take a look here:
http://www.sharcnet.ca/Software/Flue...ug/node728.htm
Enter the Evaporation Frequency and Condensation Frequency model constants. Those values are 0.1 by default. Note that the bubble diameter and accommodation coefficient are usually not very well known, which is why the coefficient can be fine tuned to match experimental data.
I hope that will help you in your research.
Old   July 3, 2013, 17:48
Anna
Gimlas,
Thank You very much! You've been very helpful.
All the best,
Annananana.
Old   September 25, 2013, 11:59
Default elias
  #18
Elias
eliastorca is on a distinguished road
I'm also working with mixture model and evaporation-condensation model for mass transfer but finding convergence problems. My case is a long and small diameter tube where the pressure drops due to friction with the walls and the fluid (refrigerant at its liquid state) has to change from liquid to gas. I define both phases and imposse velocity inlet and pressure outlet conditions but I find convergence problems. Could anyone help me? Gimlas, I can't enter in the website you propose
eliastorca is offline   Reply With Quote
Old   April 27, 2014, 01:37
ash
aasrith1296 is on a distinguished road
someone please tell me how to simulate evaporation of water from an open beaker and hence determine the mass lost by evaporation..........
aasrith1296 is offline   Reply With Quote
Old   January 6, 2016, 11:19
Amar
Amar Kad is on a distinguished road
HI Dear
can you help me on the simulation of refrigerant flow through capillary tube using fluent
i understand the physical phenomenon that i have liquid at the inlet and then phase change takes place
thank you very much
Amar Kad is offline   Reply With Quote
FLUENT - EVAPORATION and CONDENSATION SIMULATION Patryk FLUENT 18 September 27, 2020 09:23
Evaporation and condensation model in VOF ic3lemon Fluent Multiphase 0 December 12, 2015 06:56
Evaporation and condensation Model in Fluent amy24d Fluent Multiphase 5 May 26, 2015 12:20
Evaporation & Condensation model Amit FLUENT 0 September 7, 2012 06:53
evaporation and condensation in Fluent aximefu FLUENT 4 May 12, 2012 09:47
