what is the Typical cell size?
Old   February 24, 2009, 21:12
Default what is the Typical cell size?
mike
am trying to run unsteady case, and in order to do that I need to estimate (delta t)
delta t= Typical cell size/characteristic flow velocity
(this eqution from fluent.com)
can any body help in this
thanks
Old   February 25, 2009, 14:05
Default Re: what is the Typical cell size?
orca
In 3d you could use cube root of volume/#_of_cells. Just an estimate.
HTH
Old   February 25, 2009, 15:14
Ralf Schmidt
Hi!
i would use the finest grid cell for calculation. So you can be sure that flow is resolved everywhere
Best whises Ralf
Old   December 7, 2016, 08:31
Onur Özcan
oozcan is on a distinguished road
which one is preferred to be used? both approximations are applicable.
oozcan is offline   Reply With Quote
Old   December 7, 2016, 10:05
Antanas is on a distinguished road
In usual cases it is recommended dt = L / 3V. L - characteristic length, V - characteristic velocity. L = cell characteristic size may be very restrictive, but also safe in terms of convergence.
If your mesh is relatively uniform, then you may estimate cell size as cubic root of Domain Volume / Number of Cells. Anyway it is safe to use minimum cell size.
Antanas is offline   Reply With Quote
Limit on maximum cell size to minimum cell size ratio albcem OpenFOAM Running, Solving & CFD 2 October 17, 2011 12:00
cumulus cloud typical speed and eddy size Facewindu Main CFD Forum 1 March 21, 2008 19:16
cell size Baskar Siemens 4 January 18, 2006 13:34
cell size Sam FLUENT 2 March 11, 2005 03:33
cell size solomon Main CFD Forum 0 May 17, 2003 13:52
